1 - 5 of 5 Posts
Hello everyone. I just bought a 2020 spark and noticed the headlights shine a bit low. I'm not sure where on the light the adjustment is. I was hoping someone might have a picture to show me. Also, I have the ls model and there is no trunk latch button . Any ideas of how to remedy that? Thank you for your time.
· Super Moderator
21 Spark LS Stick Cayenne Orange
Headlight adjusters are going to be behind the lamps under the hood.
You can install a remote hatch release switch in one of the blank rocker switch sockets in the dash and run a wire back to the tailgate actuator. Yes, it's kind of a big job removing all the trim pieces to run the wire.
· Super Moderator
This vid might assist you. I wouldn't get too carried away with a factory preset headlamp adjustment though.
There are some plastic cogs that hold that notched adjust screw, and I suspect you have to hold them back with a screwdriver or something so the adjust screw will turn. Yes, it's a 10mm hex nut.
1 - 5 of 5 Posts
