Can anyone tell me if you can put an amp on the head unit of the USA version 2013 Spark? I'd like to beef up the sound system a bit. And if so, how to access the dash?
That's just it, not sure how to pull it out without breaking something. I don't think it possible to change the head unit on this car since it controls so much of the car's settings...Typically OEM don't have RCA outputs which would be needed for an AMP. I doubt the Spark has it, but will try to find out, unless you want to take a chance and check it yourself by pulling out the headunit.
I'd be interested in how you installed these.I plan on upgrading all the speakers adding tweeters. And adding two small pre-amped subs. I'll take pics and post after I get the car.
You cannot remove the factory head unit because it controls so many of the car's settings.Just install another deck, i dont think the oem player gives you much options to add amps.
Whats metra?yup chevrolet really screwed people their. but it can still be done, just not as easy, hopefully metra has something in the works
Metra is a manufacturer of trim kits that facilitate the installation of aftermarket head units.Whats metra?
It's going to suck having to splice into the wires on a brand new car but it's probably the best way to go about this.Many AMPs have high level inputs as well as RCAs, so you'd just have to tap/disconnect the current wires going to the stock speakers and send them to the AMP, then from the amp to the new speaker setup. Many individuals with OEM stereos run this setup.
It's not ideal, but it works.
hmm .. my 4 kicker speakers are kicking ass (no pun inteded).I have upgraded to 6x9 kickers in the rear (made a deck for them to sit on accross the back) and still the sound quality is very substandard. I think the head unit just doesn't put out the juice (or mix) it needs to.
Metra just released a full kit.You cannot remove the factory head unit because it controls so many of the car's settings.
how much is it from metra ?Metra just released a full kit.
Metra Online
Metra Chevy Spark 2013 & up kit 95 / 99-3309B - YouTube
There is an accessory that retains all stock functions.
