I'm turbocharging the Spark. The turbocharger needs an oil feed. This is typically achieved with an oil pressure feed line or oil sandwich plate. However, considering the compactness of the Chevy Spark (M300) engine compartment and oil filter location, the sandwich place seems less feasible than an oil pressure feed.Feed line to what exactly? What makes you think there's such a thing? What are you trying to accomplish?
An oil pressure indicator switch is generally just threaded into a port in the pressurized area of the block.
Do you know where the pressure oil line/pressure switch is located on the M300? Pics would help!I would think you could add an oil line where the pressure switch goes, add a tee.
Turbo charger??? Uhm, well you're on your own then. LOL
I know there's a port near the oil filter. Might be an oil line/port. I'd rather not drill the engine block unless I know for certain the locations correct.For a third gen, not sure. For the fourth gen: 2017 Chevrolet Spark - Where is the oil pressure sensor located? (repairpal.com)
Easy to find the switch itself, but not sure of it's location on the engine.
