1 - 1 of 1 Posts
Registered
Overview
A new generation of Spring Starters is here. They open up a whole new world of easy, lightweight, and safe hand starting. We have brought appropriate and high technology together and uniquely combined the best of both. Now you can fire up a diesel engine by hand more easily than starting a lawnmower -and gain big benefits in doing so.
We have all suffered starting problems. What do you do if your battery has been stolen? What happens if the machine has been left idle too long or damp has got into the electrical system? How do you get your boat engine running when you are marooned in the middle of the ocean with dead electrics?
Simple
Spring Starters combine the dependability of hand winding with a powerful spring mechanism. Operation is simple, and with a Spring Starter fitted to your engine it only takes a few moments to kick your diesel engine into life. Hand starting is no longer an all-or-nothing effort because the winding is separated from the starting. You just wind steadily until enough energy is stored in the spring, the starter is tripped to release the stored energy, and off you go. No sharp pull. No yanking. No sweat! Such smooth, steady starting, that even powering up a big generator is easy.
Spring starters use disc springs on a ball screw wound by a detachable handle which is set and tripped by hand. The starter range covers engines up to a maximum of 6 cylinders, up to 1.25 liters per cylinder. Both standard and high torque models are available in many different flange and pinion options to suit different applications. Standard and Reverse rotation options are available as well as Marinised models.
There are many reasons to fit Spring Starters:
Spring Starter on Engine
On irrigation pumps and boats, the combination of water and electrics is a sure recipe for disaster.
On construction sites batteries frequently 'disappear' from equipment or fail because of chronic vibration.
In a mine or grain mill, dust can get into switches or be ignited by sparks.
On a lifeboat or oil rig, you need a dependable backup starter that is safe to use and needs only limited manpower when all else fails.
Unaffected by long shutdowns, damp or cold, Spring Starters are ideal for equipment left in storage for long periods of time; from emergency and utility standby to grass-cutting and maintenance equipment.
In the remotest of locations sure starting is equally about ease of operation and sustainability in the most adverse conditions.
Equipment for disaster relief, military and strategic use needs to be lightweight and ready for use at a moment's notice - features which often only a Spring Starter can provide.
Our newest starters are very simple and affordable, making hand starting the smart option on a wider range of machinery. Fitting is easy. Just remove the electric starter and its connectors and bolt on the Spring Starter. Perfect as an emergency backup in a boat's locker, in case of trouble with the battery, starter, alternator, or wiring. And excellent as the primary starter for a whole host of uses where you never want to be faced with a dead engine again.
1 - 1 of 1 Posts
